Hello,
can i please know if we purchse the new Arlo Pro in the US will i be able to use it in other countires due to the different Voltage in the adapter?
Usually in the US you have 110 Volt, where as Europe/UAE has 220 volt.
So are those purchased compatible to charge in othere counties than the US?
thank you!
The charger that comes with the Arlo Pro has an input voltage of 100-240V 50/60hz so it will work fine on 220v.
The power supply that comes with the base though is 120v only.
However the output is 12VDC at 1.5A abd you should be able to find a replacement there that has the same output.
Thank you very much for the info.
