IFTTT with schedule
  • 5134 Views
hoagir
If this has been asked a hundred times, I am sorrry, but my 75 year old mind doesn't work like it used to. The discussions that I have found regarding this issue have confused me more.
I am trying to have 3 cameras all record if ANY of the 3 sense motion, but ONLY between the hours of midnight and 7 am.
After 7am I would like to have each camera record individually when it senses motion.
Can this be done?
Thanks.
Yes... with custom MODES ( add a mode )
first set up the new mode with these rules; Any camera triggered will record to the three
( hint; create the mode with first cam and save, go back and edit the same mode to add additional cameras/rules)
A senses, A records ( continue as below )
A  > B
A > C
B > B
B > A
B > C
C > C
C > A
C > B
Use this custom mode with the above rules in the Schedule for the hours 12 midnight to 7 am
At 701 am, use just the normal ARMED mode either manually or in schedule so each camera is on it's own
A  > B
A > C
B > B
B > A
B > C
C > C
C > A
C > B
hoagir
Thank you so very much. You are truly kind!
That worked like a champ.
Now you've done it.  You're giving him a swelled head...
