  • 5 Replies
  • 4045 Views
Sacfireman
I upgraded from Arlo to Arlo Pro,... I switched out the cameras so that they are exactly in the same spot... Same ambient light... But the Arlo pro is fuzzy, grainy, and halos from other lights.. To the point almost nothing is visible.  Need help... The ambient light was the before and the normal Arlo had no problem seeing in the dark... Please help... I have 2 cameras were there a useless.  If this cannot be resolved.. I will go back to the regular arlo system.  But I really want this to work like before. I have pictures to show the difference.. HELP!
Sacfireman
Thank you... Turns out the2 cameras that were grainy.. Still had the plastic on it... Embarrassing... Got all the others... I am at work and not able to make sure.. Had my wife check and sure enough. Thanks
5 REPLIES 5
Post the pic here....( above next to chain logo)
 And, not to sound foolish, did you remove the plastic from the front of camera?
and if if as you say, contact Netgear
Sacfireman
Talk you for the reply.. Yes I removed the plastic..lol... every time I press the chain..my ipad goes blank..will have to do it from computer
Sacfireman
Sacfireman
Sacfireman,
Thanks for letting us know the resolution as this information will surely help others. I'm sure you're not the first to experience this.
