I've removed the app and reinstalled and turned off and back on my base station. I can log in and see cameras when I'm on my PC.
I can't log into my Arlo Pro system either on my iPhone app. Same as the outage last week!
Try force stopping the app and try again. If needed, reinstalling the app should fix things.
jguerdat: I've logged out of the Arlo app, deleted it, rebooted the iPhone, and then reinstalled the app and logged in again but am still unable to view the cameras. Are there other suggestions?
Note that if I log into my account from the web login (https://arlo.netgear.com/#/login) the cameras work for a short period of time and I can view a live feed but it still reports the base station as offline so something is still not working correctly on the Netgear side. Do you have any informatoin or updates?
It may be an iOS issue and I don't have any of those to test.
Not sure why things are being reported as offline - I'm not experiencing any such problem. You can try power cycling the base just to eliminate that but if that doesn't work we'll just have to wait while whatever gets fixed.
The number you called was not Arlo Customer Support. That is a site trying to steal your infromation from your computer.
To contact Arlo Customer Support see the green banner at the bottom of this page.
Brian
I don't think you went far enough in the Support pages. The number they publish there is: (408)-638-3750. Is this the number you called? Support is probably swamped right now with calls and chats.
Try turning off your phone for a minute or so then turn it back on.
From this reply, I can't see what type of phone you are using - I think you said it was an iPhone.
Are you trying to see the system in the app or through a browser on the phone?
Brian
If you are using an Android device, the app was updated last night so be sure you are updating to the current version.
Brian
If the three lights on the base station are all green, you are not offline. It appears that some iphones are reporting falsely. I am not sure if there are certain areas that aren't working yet, but my iPhone 6 is working fine in North Carolina.
Let's start with the browsers you tried. This morning I went into Google Chrome and deleted my entire browsing history which included cookies. That worked for me. Since I don't normally use Microsoft Edge or Firefox, I opened them and of course I had no browsing history to delete,so they worked fine, but I had to install Flash to see Live View..
Are you willing to try to delete your entire browsing history?
Brian
When you say you reboted the system, did you just turn off the power to the base station or did you do a factory reset witha paper clip?
Brian
I got someone overseas as well and he acknowledged the outage but gave no solution. Horrible customer service. I'll definitely not be recommending these cameras any longer.
Same issue here but not confined to iOS. Will no longer work at all on Firefox on computer. Safari shows cameras for a short time but they never connect with base station and will eventually present the connectin error message.
Spent (lost) the day with both chat and phone tech support. Chat put me through every possible troubleshooting option to no avail. They claimed it was an iOS problem and they were able to recreate the issue on their iPhones but could not explain the reason. They seemed to think Safari on the computer worked fine so blamed the iPhone but it was clearly evident they just didn't wait long enough in Safari to see it fail. They passed it up the tech line and said there would be return contact in the future.
Contact with phone support was also made later in the day but after losing another 45 Mins, the tech admitted it was a known issue and they were working on it and would call or email when fixed. It is Midnight...no change. And I see it appears they have not addressed in this forum either.
The base staton lights are all on and green and it is connected to the internet. Chat tech said everything on their end was fine. It was only after the lengthy phone call that the issue was acknowledged.
Not pleased with the lack of response and secrecy. It was only a week ago that they had server issues at their end but claim that was fixed. I wonder...
Are you using ios or Android as your mobile device.
If worse comes to worse, you may have to do a factory reset to restore the system back to its original specs. If you decide to do a factory reset using the paper clip, you will need to delete all your devices and after the reset, add the base back in and then resync the cameras one at a time.
If you are using and android mobile device, there was an update last night and you should install it.
Brian
The problem with calling Customer Support when we have these massive failures, is that they have not been informed about the problem and like us, they just try to solve the problems based on their training and previous problems.
Customer Service should be the second people to be made aware of the problem with an appropriate response, after the customers are informed, of course.
Brian
I'm right there with you. Our whole system is down. It's always fun to know that overpriced cameras have outsourced customer service to India. Good times!
