I can't figure out how to delete multiple videos at the same time
  • 1 Reply
  • 5386 Views
myarlo23
How do I delete multiple videos taken on the same day on the same camera. Thank you
EDIT: Problem solved. Thank you for your help.
brh
@myarlo23
the easiest way that i know of is to go into your account in your web browser and go to the Library. At the top right of that page you should see the words, "Select." Click on that and then click on any videos you wish to delete. There will also be wording to Select All. When you have selected all the images that you wish to delete, click on the trash can Icon. Then Click on Done at the top of the page.
Brian
brh
@myarlo23
Brian
