I just added a Q to my in home setup. I had 3 Pro's that have been set up in modes "arm", "disarm", "geofencing", etc. So today after adding the Q, I tried to add it to the modes but it won't let me. I click on modes, then it shows My Devices and under that it shows "Arlo Base Station" and "Arlo Q" but they appear separate. The Q doesn't show up in the Base Station portion. Am I missing something?
You'll have to add a rule to each mode that includes the Arlo Q
The Q cameras are considered a separate system, just as would be the case if you had a second base station. You currently can't mix systems in your modes. There are posts in the Idea Exchange here that you can add kudos to for future consideration. The Statuses in there indicates it's being worked on but no timeframe.
