  • 2 Replies
  • 1464 Views
Ritchtopher
Why doesn’t my hub connect to the internet?  The power light is on, but not the internet light.
DannyBearAgain
When the internet led shows nothing it usually means a loss of the Ethernet connection to the local router.
Check the Ethernet cable is plugged in correctly, reboot router and base station, try a different router Ethernet port. If no joy the base might be faulty.
@Ritchtopher:  If you have a PC with an ethernet port, you can also try connecting the ethernet cable to the PC and check the ethernet ports+cable.
