  • 11 Replies
  • 4414 Views
  • 2 Likes
  • 5 In Conversation
McRider
Please tell me how to schedule my cameras to be armed from 8 pm to 6 am.
Same schedule, two time periods.
11 REPLIES 11
There is an FAQ here on schedules. Basically, you can't span days. use 8PM to 12AM and then 12AM to 6AM.
correction.... 8pm to 1159pm  , next day 12am to 6am  ( the full min is covered btw )
Correction on the correction, @TomMac  - it used to be 11:59PM for the stop time and it would be fine for the whole minute. Dunno when it changed but another user tested and found that doing so now leaves that minute unprotected. I tried it myself and found this to be true. So, now use 12:00AM as both the stop and start time so the mode is selected totally.
McRider
That is two schedules.  I can only use one at a time.
brh
@McRider
The second schedule should automatically activate at the proper time and the first one should automatically turn off at the proper time. Set both of them to Armed or whatever mode you chose.
Brian
McRider
Ok, I figured out how to do it on my computer versus my phone.  Didn't see the second time frame.
However, I set the time on the computer to go off of armed state at 6am, but phone still shows 5 am.
For some reason, the apps seems to have issues displaying and setting anything under the Mode tab. Sometimes it works right, sometimes not. I recommend using the web browser of this.
jojo220
jojo220
Does anyone know why these bogus links keep popping up?
