How to remove small greeting banner on bottom of iPhone home screen from Arlo pro?
  • 4 Replies
  • 7980 Views
rodzulu
Started to get a small greetings banner ( good morning good afternoon ----- ) on the bottom of my iPhone home screen from Arlo pro. Quite annoying anyone know how to get rid of it ?
JessicaP
Hey @rodzulu,
Could you show a screenshot where the small greeting shows on your iPhone?
rodzulu
JessicaP
This appears to be an iOS feature, not Arlo. Try out the following and see if that removes the "Good Morning" message.
  • Go to your Home Screen and swipe right to enter the Widget Menu
  • Scroll to the bottom of the page and click "Edit"
  • If you have "Siri App Suggestions" on your list (not on "More Widgets" list), then click on the no entry icon and click remove to disable it
Or
  • Go to your iPhone Settings > General > Handoff > Toggle off "Handoff" (if you don't use this function)
rodzulu
Results are still under review
