How do you guys keep your cameras from getting wet, like... foggy? I have that problem where I live, most of the mornings are foggy and my cameras get "wet" and can't see clearly. If someone is outside at night, I won't be able to see clearly because of that.
Try Rain-X or similar on the camera lens.
I have been having the same problem.
I used an old take out container to surround the camera.
Looks funny, but if it works..... Does the edges of the cup show on the video? I tried something similar but I didn't like it because it was blocking the view a litte bit on the sides.
I tried but didn't work. May be I need to try a different type of rain repelent. I used window cleaner with Rain X
If the camera is positioned correctly it does not pick up the edges.
We had a few nights with very high levels of dew. This really did the trick trying to monitor the coyotes entering my property.
This one was shot using my modification.
https://www.youtube.com/watch?v=UaJ7msSa0U4
What about on a windy day, any problems with it moving around or amplifying wind noise?
