Anyone have phone number for Arlo?
They changed over their support, so it now requires that you use the app. If you go into "support", you should see a contact section. If you have a subscription, you can get phone support there. Note you can't do this from the browser, you need to use the app.
Googling for a phone number generally leads to a scam support site.
