VMB4000 base will nor be discovered
  • 1 Reply
  • 1019 Views
SalG1
Any help would be appreciated. Followed all the fixes but the base station will not be discovered.  Factory rest and still nothing. The power light is green and the internet light is green and blinking. Removed the app and reinstalled and also tried to discover on the CPU. This seem to have started maybe after an update. Thanks in advance.
I had a similar issue once that turned out to be a bad base. It looked like it should work but wasn't. When I installed a different base, all was fine.
