  • 2 Replies
  • 17058 Views
ade0007
Hello,
How can I connect Arlo Pro to micro sd card, sd card or an external hard drive so I can watch it on my mac desktop? I haven't been able to find arlo aplication for mac desktop. I only found versions for ipad and iphone.
Use your browser , there is no app for that ;  https://arlo.netgear.com/
As to the USB drive... the Arlo PRO can ONLY use a usb drive connected to the Pro Base thru the usb port.  The files it stores are not directly viewable.
The drive must be "ejected" ( normal way to remove a usb drive ) from the base and then you can view the mp4 files on it in your computer
Hogger308
Why wasn't the ability to retrieve files loaded to external memory programed into the base? You can download, but not upload> I hope the will be a revision for this.
