  • 5 Replies
  • 6527 Views
  • 6 Likes
aliciam
I cant seem to figure out how to get the system to stop notifying me via email everytime a motion is detected from the cameras...any thoughts?
steve_t
Master Master
Edit the mode you're recording in, possibly ARMED.
Each camera probably has a RULE
Edit the rule and scroll down. There are two boxes, one for push notifications and one fo emails. Uncheck the emails box.
Do this for all the cameras you want to turn emails off for
5 REPLIES 5
steve_t
Master Master
aliciam
I can't tell you how much I appreciate your response thank you SOOOO much!
Don't forget that there's a ton of FAQs here which also tell you the same thing as well as how to handle many other situations.
Jbharrison
How do u get to edit mode? Can not find that option?
steve_t
Master Master
How do I edit an existing mode on my Arlo system?
To edit an existing mode:
  1. Launch the Arlo app or log in to your Arlo account at arlo.netgear.com
  2. Click or tap Mode.
  3. Click or tap the device whose mode you want to edit.
  4. Click > or tap the pencil icon next to the mode that you want to edit.
  5. If you are editing a mode for an Arlo Wire-Free or Arlo Pro Wire-Free camera, click Edit or tap the pencil icon next to the existing rule that you want to edit.
  6. Edit the mode.
  7. If you are using the Arlo app, tap Save after each edit, then < Edit Rule to return to editing the mode and Done to stop editing.
    If you are using a computer, click Back > Save.
    Your changes are saved
