  • 4 Replies
  • 2278 Views
AM28
How do you disarm one camera on your base/account? (4 others are armed) Meaning this camera is on but will not detect motion/send notification? When I uncheck the motion box in the Edit Mode section in the app, it does not work/save.
dcfox1
You can keep the "Motion  is  Detected" selected and then select "do nothing" then unselect Notifications and you should be able to save. It won't record or send notifications you don't want but you can also just turn the camera off as it's not doing anything unless  you just want Live stream on that cam.
AM28
When only “Motion is detected” box is checked, “Save” is grayed out and it won’t let you save this setting.
(Yes, I want this camera to be just live stream for now)
dcfox1
Have you tried it on my.arlo.com page? I just tried it as I described and the save button was green and it saved.
Or create a custom mode with that camera NOT having a rule.
