I want to record for 6 continuous hours in the day. I could only get 20 minutes while I was actively on the app. Once I put my phone down and left it, it stopped recording. How do I set the recoding time for hours, from 10am to 4 pm??
It will not record for continuous 6 hours... It is a "motion triggered record" device...
You ARM the camera and if it sees motion THEN it will record. If you force a manual record session, it will only run for about 30 mins to preserve battery life
You can schedule the times you wanted for motion record...but there will be no recordings until motion is detected
