How do I set the Arlo Pro cameras to record longer than the 10 seconds?
  • 2 Replies
  • 8989 Views
karennorth
How can I change the camera to record for more than 10 seconds?
Go to the Mode your using and EDIT it... under record section there is a slider for time, adjust and then save
To adjust video recording length:
  1. Tap the Arlo app on your mobile device. You can also enter arlo.netgear.com in the address bar of a browser.
  2. Click or tap Mode.
  3. Click or tap the base station or camera that you want to adjust.
  4. Click or tap the pencil icon next to the mode that you want to edit.
    Note: The Disarmed and Scheduled Modes do not apply in this case. Only active modes such as the Armed mode can adjust recording length.
  5. Click or tap your preferred edit or pencil icon under Rules.
  6. Click or tap the pencil icon next to Record Video.
    Note: Record Video must be enabled to edit recording length.
  7. Move the Slider Controlslider control.pngto your preferred recording length.
  8. Click or tap Back.
  9. Click or tap Save.
    Your recording length is updated.
watchdog99
Luminary
Luminary
ditto...follow the post above.
