How can I change the camera to record for more than 10 seconds?
Go to the Mode your using and EDIT it... under record section there is a slider for time, adjust and then save
To adjust video recording length:
- Tap the Arlo app on your mobile device. You can also enter arlo.netgear.com in the address bar of a browser.
- Click or tap Mode.
- Click or tap the base station or camera that you want to adjust.
- Click or tap the pencil icon next to the mode that you want to edit.
Note: The Disarmed and Scheduled Modes do not apply in this case. Only active modes such as the Armed mode can adjust recording length. - Click or tap your preferred edit or pencil icon under Rules.
- Click or tap the pencil icon next to Record Video.
Note: Record Video must be enabled to edit recording length. - Move the Slider Control
to your preferred recording length.
- Click or tap Back.
- Click or tap Save.
Your recording length is updated.
ditto...follow the post above.
