How can I get a stronger WiFi signal to my cam that is outside
  • 1 Reply
  • 1528 Views
Rockyban
Two ways, tho the second is the only true way to expand the total range of a number of cams...
1) move the base unit to a more central location either by ethernet cable ( up to 300ft ) or use a wifi extender with ethernet port
2) add a second base ( using one of above or second access point ) and sync the closest cams to each base
( there is no limit of bases on any level account )
