Hi, Is it possible to do simultaneous monitoring from both my cell phone and on my pc?
Thanks in advance.
-David
Not if you are the Primary account holder. ( as then you will get bumped when the other device logs in )
What you can do is SHARE ( GRANT ACCESS ) to another email address and then that email/account can view at the same time without bumping the other off.
Thank you!
