  • 3035 Views
Freebird57
When the wind blows and it rains it never stops going off. How do I set it and keep the sensitivity bar where I need it. ? It's killing the battery so fast I get 200 a day..
create a new custom mode without the level of sense or alerts called RainDay... use instead of normal mode on those days.
Freebird57
How do I do that?
pc2k17
Hero
Hero
You didn't say the OS, but on android...........Go into modes, tap Add a Mode, follow the on screen prompts and choose your settings. Be sure to set motion sensitivity to lower than you normally have. Then switch to that Mode when it rains or is windy and test it. If sensitivity is still too high, edit the mode, edit the rule, edit Detect Motion, adjust your sensitivity until you get it to where you'd like.
