Homekit Token Reset
Thank you
Unfortunately, that did not work. I've tried every method of connecting to HomeKit to no avail.
Which version of the Arlo mobile app are you using? Have you tried removing and reinstalling the app? Which version of iOS is your phone or device running?
I also reset the token again in case that triggered it if you want to try and reboot again then remove > re-install the app. This method has worked previously.
Arlo 3.6.5
iOS 15.5
I reset it again, Can you try the various methods in this KB here: https://kb.arlo.com/000062279
Can you try updating to the latest version of the iOS Arlo app 3.6.6? If you don't see the update you can remove and reinstall which I would suggest since we are trying to troubleshoot this issue right now.
