Home address not found
  • 4 Replies
  • 3997 Views
McOrion
Good evening,
I try to configure geo-localization.
If I manually add my address (TOWN, St. NAMEOFSTREET, NUMBER) Arlo doesn't find it.
If i manually set it on map, later, when I should save, it requires I write address (which he will not find, as above).
How should I proceed to teach it where is my home?
In this moment I would like to have Geofencing active. It should turn off when I am at home and enter in programmed mode between 22:00-08:30. It doesn nothing, during this night schedule. Schedule works, if selected alone, anyway.
Regards
McOrion
McOrion
Before any modify... now I find correct address on it: Mistery 😄
McOrion,
What error are you seeing that indicates the address is not found? Are you sure you're entering the address accurately? (street, city, state, zip)
McOrion
Hi,
Yes, but State.
Is it correct so:
Via NAME NUMBER, Mascalucia, Italy, 95030?
Mascalucia is TOWN. I didn't insert Italy, before.
Regards
McOrion
McOrion,
Do you get different results if you specify Italy?
McOrion
