Hi all not sure how to enter my wifi pass into router to let base station no its open. Have changed provider and can not see how to put new provider in i am stuck
Hi thanks for reply, yep got it in the end needed to delete my old wifi provider then instal my new provider, with wifi key before it would operate took me like 3hrs but got it in the end.lol
You base station NEEDS access via Ethernet and will dynamically get it's IP address from the router....
There is no access into the base wifi as it links to cameras ONLY
