Hearing Aids interference
Hi All,
Just installed an Arlo Pro system for my mother in law. While navigating on the app turning things on and off to get used to the system, her hearing became muffled while wearing her hearing aids. Does anyone else have, heard or especially know how to fix this problem? Thanks!
bongomauka
The only thing it might be is the wifi interference from the base unit ... but have never heard of this before so don't have an answer
Sure it's not the hearing aid ( low batts , etc ) since you prob already had wifi router to plug the base into.
