  • 5 Replies
  • 880 Views
Hockeyfox
I have several Arlo Pro camera's and batteries. All batteries charge and work well with the exception of one battery. It charges fine, I can live view, but it will NOT detect motion. It definitely is the battery causing the issue. Anyone have this issue and is there a fix? Is it possible this is a multi cell battery and the cell that is responsible for detecting motion is bad?
5 REPLIES 5
How do you know that?  Have you tried swapping the battery with the one in a different camera?
Hockeyfox
Yes, have multiple batteries and cameras. Switch them out and just the 1 battery doesn't detect motion, no matter what camera it is in. All of the other battery/camera combinations work.
ShayneS
Are these all Arlo branded batteries?
Hockeyfox
Yes, they are all Arlo branded.
ShayneS
Understood, it sounds like that battery might be going bad, might require replacing.
