My wife and I have iPhone 7 pluses and when I go out of zone it arms the system but it shouldn't because my wife is still "in zone". Also, my wife's phone is listed two times in the list of enabled devices and I can't delete one of them. I've deleted her phone and re-invited her and it adds two of her phones again to the list. Geofencing was working for a long time. I think ever since the latest update it started having problems.
The Geofencing radius size will not stay at "medium" after i select it. I select medium and then click save and it goes right back to small.
Hey dazednconfuzd,
If you're having problems with your Geofencing not working properly, try looking at this article for troubleshooting steps you can take to improve performance for Geofencing: Why isn't the Geofencing mode working?
If you're still having problems, contact the Support Team to further investigate this issue. You will find several options for contacting support in the provided link.
IF the app on phone 2 is opened, it seems to enable the location again...for a period...and then disabled again. Anyone experiencing the same??
Yes, we experience exactly the same problem - really annoying !!!
@Arlo, when will you fix this problem
... or maybe slightly different. After some time the 2nd iPhone is not location recognized.
Which means that even the 2 iPhones are outside the defined Geofence the Arlo alarm is not set as the system belives the 2nd iPhone is still at home :-
Well, my wife and me/I have an iPhone 10Xs each.
My geofencing seems to work fine even the Arlo app is closed completely = even not active in the background on iPhone.
However, my wife's geofence seems only to work properly if the Arlo app is at least active in the background on her iPhone.
If she close the Arlo app completely on her iPhone the geolocation seems not to be read from her iPhone after a while.
This is really annoying because if this happen you never know if the last geolocation read from her phone was status "At home" or "Away" ...
This means if I am "Away" and the last read from my wife iPhone was "At home" - and my wife moves "Away" the alarm won't arm as it's supposed to to in the "Geofencing mode".
If she moves from "Away" to "At home" - it won't automatically disarm as is should.
Btw. both iPhone's location settings are exactly the same !!!
This is strange and really annoying !!!
ARLO PLEASE FIX THIS PROBLEM ASAP
Br,
Ole
