  • 1 Reply
  • 2342 Views
Gora
I have an Arlo Pro Base station set up with two cameras. I am trying to figure out how to get the alarm to sound when geofencing is enabled. I have created a mode to turn on the siren when motion is detected in either of my cameras, but this mode has to be turned on manually and does not work with geofencing.
You can use that mode in either Home or Away.  Depending on your needs, you could insert it into the schedule and use that for either Home or Away.
