  • 13 Replies
  • 4171 Views
  • 2 Likes
  • 5 In Conversation
Retired_Member
Not applicable
What is happening? My system that have been up and running for years lost connection to all cameras and cant get re-synced again.
I see several posts regarding offline cameras. Is this a server side issue?
13 REPLIES 13
Retired_Member
Not applicable
They won't even sync stand on to of the base!
https://photos.app.goo.gl/4QQrcxdkTvMxFWX97
What are your base's LEDs showing?
Retired_Member
Not applicable
Off means there are no cameras connected or the base needs to be claimed. Do all devices show in your account, even if offline?
https://kb.arlo.com/000039100/What-do-the-LEDs-on-my-Arlo-SmartHub-or-Base-Station-mean
Retired_Member
Not applicable
Yes 
Edinburgh_lad1
There's an issue with some systems/cameras being offline. Support are aware, but Dev Team have no timescale to fix this issue. Welcome to wonderful Arlo, where one spends a lot of money and receives a half-baked product instead.
This company has NO RESPECT for its customers.
Retired_Member
Not applicable
Yes, this will cancel my subscription and I will buy another system on Monday.
My system have been offline for 2 days now and nothing works.
I manage to delete a camera and after 2 hours of trying to pair it again it finally synced. 3 other cameras also came online, but I pressed play on one and now they all are offline again.
When the system status page  says no issues at Arlo site you know that they lie!
Retired_Member
Not applicable
It also drains the batteries in the cameras!
JDSec
Mine has also been offline since Aug 28
however does somehow capture what I have set to smart recordings . 🤷🏻‍♀️
 annoyingly that means constant notifications also.
I’ve also cancelled my subscription for now and I’m  looking at other options
Retired_Member
Not applicable
I got some sporadically notifications from one camera, but not smart notification as I still have subscription for. But all is still offline.
Maybe try removing one camera from the account and resyncing.  You'll likely need to use the manual sync instead of using "add device".
If that doesn't resolve it, I suggest getting phone support via the app.
Retired_Member
Not applicable
Done that already, do not work, the cameras takes hours to sync back again.
Retired_Member
Not applicable
Had a chat with the support department..... First they blamed my bandwidth (I have a gigabit fiber connection and a unifi dream machine pro that utilizing 3% of my bandwidth)
He also told me that I was supposed to use my phone on wifi to make a speed test and that has to be the most stupid **bleep** I ever heard! I have wifi 6 and the Arlo cameras have no connection to my wifi (as the use their own base as wifi access point) as it's connected with a cable.... So doing a speed test on wifi 6 would not tell him a single thing about my Arlo connection as it's not even comparable.
When I pointed this out he just said that my base station was broken because it was from 2018.
So good bye Arlo, I will never buy a product from you again!!!
When I
