Is there any way to set enhanced geo fencing so that when you are home some cameras stay on and some turn off?
I would like when I am home my interior cameras to turn off and exterior cameras to stay active. When I am not home I would like all cameras active. Aside from buying another base station is there a way to do this?
Geozone allows an AWAY and HOME setting, what you need to do first is create CUSTOM modes for he cameras to split them up ( like inside/outside ) and then use then for the needed modes in same
So is geozone the same as geo fencing? Also, is it available to do this on the arlopro. I can’t see an option for only arming some cameras in home mode.
