Does The Base Station Have To Be Hard Wired To My Router?
  • 12948 Views
solly316
Two questions before I buy: 1. does the base have to be hard wired connected to the router? why can't it simply connect via wifi like everything else? 2. where is the ideal location for the base? i want the alarm in the living room since it makes the most sense but this hard wired thing has me confused. thanks
steve_t
Master Master
Yes, the base needs an ethernet connection. If you want to put the base station remote from your router, you can use a wireless range extender with an ethernet port. Obviously this is likely to introduce minor lag.
The most ideal position for the base station is the most central point between all of the cameras. The siren is extremely loud and piercing so does not necessarily have to go in a room where people will be
steve_t
Master Master
solly316
thanks so much. my router is buried in a closet and that location is not ideal. i'll have to hire a contractor to run the line under my house to the location i want it or buy this extender you're refrring to, correct?
steve_t
Master Master
Yep. The base station needs power and an ethernet connection with internet access. Those would be the ways to do it remote to your router
