Difficulty with VMB3000 base station after moving wifi router
  • 2 Replies
  • 1770 Views
Geoff_VC
I have a VMB3000 base with 4 Pro VMC4030 cameras.  We had some office layout changes and the base station was disconnected for a couple of weeks.
After reconnecting the base station - 2 of the 4 cameras are working - but I cannot get the other 2 to sync with the base.
I press sync on the base and then sync on the camera - but I don't get any shutter sound or any lights changing on the camera at all.  When I pull and replace the battery in the cameras not working I get a solid blue light and the 2 that are working show 85% battery.
I removed one of the cameras that wasn't connecting and when I try to add it as a new device through the web portal I get a "No Base Stations Found" message.
Not sure what to do next.  Any ideas?
If you turned the base off without removing the camera batteries, the batteries are likely dead. The cameras will keep trying to connect to the now-nonexistant base, draining them. Charge the batteries and things should be fine.
Geoff_VC
Thank you I think this is it.  I reset the base and it connected and I am re-charging the camera batteries.
