Hi, I bought 4 arlo pro cameras And installed them in my apartment in Colombia.
I have a huge problem trying to watch the cameras, as they have a delay of 60 to 90 seconds. I know it isn’t my internet (15 mbps), as I have another camera for my baby and the delay is only about 2 seconds..
It isn’t the distance to the base, as my apartment is small and I have one next to it, with the same problem.
Has anybody solved a similar problem?
Many folks post their download speed but usually it's the upload speed that is the issue. Test yours with speedtest.net.
I ran the test, and the upload speed was 13.4 mbps
That's good news. However, there's more to it than just your upload speed. Use a computer or an appropriate app on the phone for traceroute to arlo.netgear.com. On a computer, open a command window and type:
traceroute arlo.netgear.com
(on Windows, use tracert instead of traceroute).
Ignore missing data noted as "*" - just watch for the numbers. Anything with triple digits (>100ms) is a problem. The more you have, the greater the delays. If you see a lot outside of your area, that could well be the issue.
