Delay In Recording
Hello,
I noticed there is a delay when my Arlo Pro cameras record. Is this normal? At least 5-10 seconds before it start recording.
The best lag time is about 2 seconds. Longer than that implies either a positioning issue or possibly a WiFi connectivity issue between the camera and base (distance, WiFi quality due to interference, obstructions within walls and ceilings, etc.). Try temporarily moving the camera to a different spot, perhaps near the base, to see if things change. If you have multiple cameras, swap them around to see if the issue stays with the camera or location.
i have the delay issue also, and even 2 seconds is way to much this is a big deal breaker i'm about to return my PRO
