The Arlo Pro camera I've set up to monitor my front porch is having a hard time deciding what to do when it gets dark:
https://dl.dropboxusercontent.com/u/110123227/IMG_3844.MP4
This behavior goes on for hours. Turning night vision on/off makes no difference.
This issue has been addressed in the 1.090.0.0_9945 firmware release for Arlo Pro. Be sure your Arlo Pro is updated to the latest firmware version.
Please let me know if you continue experiencing this issue.
Try and change the angle a bit more towards your front light.... it must be sitting on the threshold level to B/W - Color.
Try and turn out the light and see what happens too , just to cover all bases
last, if you have another PRO, swap them and see if the other one does the same thing.
Cyrano,
Did adjusting the location of the camera as suggested above resolve the issue?
Please let us know if you are still seeing this behavior,
ok, so i just RMA'd a camera for the going "offline" problem and battery draining and now i have this problem with a different camera.
Tried the suggestion above but still doesn't work.The problem began November 8th
Here is my video sample:
Shadowboricua,
Are you getting this behavior in a entirely different well lit location as well? Does this camera behave this way regardless of time of day/location?
None of the other cameras are doing this (KNOCK ON WOOD!)
The camera only does this at night, switching continously from infrared to non-infrared setting. Today, I tried taking the battery out for 1 min, removing and re-syncing the camera and this is still happening.
I am getting VERY frustrated with the Arlo Pro. Like I said, I just had one camera RMA'd for other reasons and now this.
Has the OP fixed this problem? Please respond.
I turned off "NIGHT VISION" on the camera and it still switches back and forth from Monochrome to Color, just without the IR being activated. Again, this only happens at night. Any ideas?
Another RMA??
I've got the same issue. Cameras start receording in black and white regarless of the night vision setting. Seems like this is something the netgear team needs to resolve ASAP.
@jguerdat I don't want to hijack this tread but my regular Arlo Wire Free camera's don't do that. When I turn of night mode on the original Arlos, it turns off night mode completely. I ended up having to swap the Arlo Pro for the original to get a good picture.
BTW: My post is here:
Thank you all for the details on this issue. I have escalated this topic for further investigation and will post an update once I have more information.
Just to show that it does not seem to be related to IR; because it happens even with IR off, the video below shows the proble with Night Vision off.
Same issue with one of the cameras, it was working for some time, then started doing this. Swaped for another camera and the issue went away. Does this unit have to be replaced?
How can I be sure I have the latest firmware installed?
