  • 4 Replies
  • 8978 Views
  • 4 Likes
jkramer77
Our Arlo hit very low battery recently.  When I went to charge it, I began receiving CONSTANT push notifications and emails that the battery is at 0%.  And I mean constant....about one every few seconds.  Is there a way to turn these off while I charge the camera?  My phone is just constantly going off while I try to charge the camera.
ShayneS
jkramer77,
Have you tried to reboot the Base Station? a couple suggestions would be to reboot/reset the Base Station & Remove/Resync the camera.
ShayneS
jkramer77,
pc2k17
Hero
Hero
You shouldn't get notifications about a low battery while charging the battery. Sounds like you ran it down too far. Check this out....
https://kb.arlo.com/000052305/My-Arlo-Pro-or-Arlo-Pro-2-battery-is-dead-what-do-I-do
jkramer77
I was also advised to turn the camera completely off from within the app.  Am going to try doing this and, alternately, turning off the base station and will report back.
jkramer77
That did it.  Had to remove the camera from my system then re-sync it.  Thanks everyone!
