I am considering purchasing the Arlo Pro camera system, but I need to get some information please. Can my Schlage Connect keypad door lock be connected to the Netgear Arlo Pro camera system hub, so that I can access my door lock remotely via my wireless router, using the Arlo Pro hub? (The Schlage Connect door lock is a Z-wave device as I recall.) Thank you.
The short answer is NO. The Arlo base is specifically designed to only communicate with arlo cameras and can not be used to control other devices. In fact, the password to the router itself isn't provided by arlo and you can only connect your cameras to the router by going thru the arlo app where this negotiation occurs. It's not a standard router, rather a specficially designed router for the sole purpose of connecting to arlo devices. (Arlo/Arlo PRO)
You may be able to do some twiddling with IFTTT or SmartThings.
