Combined two homes. Can I have one Base Station with older model cameras and add new cameras?
I have combined two homes. Now I have two base stations and two different generations of Cameras. Can I just use one base station with older model cameras and can I purchase just new generation cameras to add to my basestation or do I need a whole new base station if I add newer cameras?
The two Base Stations are VMB3000 and VMB4000. The two cameras I have are Arlo Pro VMC4030 and the other doesn't seem to have a model number on it but has this number printed on the inside: 4N71697L290D2. I just want to know if I can continue to use one of the base stations with both cameras or do I need to purchase a new base station if I want to upgrade and add a new camera. If I upgrade the base station can I still use these cameras? So many questions.
Your cameras are all compatible with all bases. Don't forget that the free plan is for 5 cameras so if you exceed that you'll need a plan.
The issue of new cameras depends on the base and the exact cameras since the Ultra and newer may need a SmartHub to work best. Pro 2 and older don't need this.
