the clips are 10 seconds. How do I increase the length of time for the clips? I just purchased this system instead of Blink however I now see that you have only 10 second clips and Blink offers 60 second clips. I need to know if I can extend this 10 second clip if not I need to return the unit.
yes u can
go to Mode youy using
click > to edit
pick Camera
Record Video , edit >
Change the time on slider bar
Hit the Back button
Scroll all the way down to the bottom of page
Hit Save
BTW, search is your friend
yes u can
click > to edit
pick Camera
Hit the Back button
Hit Save
I don't see any option to change recording time. The screenshot shows all I see.
Go to Mode
Click on Add Mode
Give it name
Click next
Pick your camera
Click next
Select trigger
Click next
Adust sensitivity
Click next
Select camera again
Click next
Click the right arrow next to the Record Video
Adjust your time.
Click Save
Repeat for reset of cameras
I tried that as well. It's like the record length and notification options disappear completely. When they reappear the slider is greeted out. I'm going to reset everything when I get home.
it will be there after you save too.
Click on the right arrow next to the new Mode name
Click Edit for the camera rule
Click on the right arrow next to Motion is detected.
time slection is there
Try the web browser, there must be a bug in the iOS version. I did notice some issues since the last update
