  • 8 Replies
  • 6905 Views
  • 6 In Conversation
tcuozzo
the clips are 10 seconds. How do I increase the length of time for the clips? I just purchased this system instead of Blink however I now see that you have only 10 second clips and Blink offers 60 second clips. I need to know if I can extend this 10 second clip if not I need to return the unit.
yes u can
go to Mode  youy using
click > to edit
pick Camera
Record Video , edit >
Change the time on slider bar
Hit the Back button
Scroll all the way down to the bottom of page
Hit Save
BTW, search is your friend
8 REPLIES 8
yes u can
click > to edit
pick Camera
Hit the Back button
Hit Save
iGoldenEye
IMG_0925.PNGI don't see any option to change recording time. The screenshot shows all I see.
arcorl
Go to Mode
Click on Add Mode
Give it  name
Click next
Pick your camera
Click next
Select trigger
Click next
Adust sensitivity
Click next
Select camera again
Click next
Click the right arrow next to the Record Video
Adjust your time.
Click Save
Repeat for reset of cameras
iGoldenEye
I tried that as well. It's like the record length and notification options disappear completely. When they reappear the slider is greeted out. I'm going to reset everything when I get home.
arcorl
it will be there after you save too.
Click on the right arrow next to the new Mode name
Click Edit for the camera rule
Click on the right arrow next to Motion is detected.
time slection is there
Maenke
It's gone on mine too. And one of my modes won't record at all anymore.
What devices are you using and what OS? Have you tried a browser, too?
Maenke
Try the web browser, there must be a bug in the iOS version. I did notice some issues since the last update
