  • 1 Reply
  • 1525 Views
FancyMonkey
<p>Is the only way to tell the battery is fully charged is to pull the camera up on the app/webpage and see that it says 100%?</p>
Streak2
Master Master
The blue led that flashes as you plug in the charger will turn solid blue when fully charged providing you have tuned off camera led in the settings.
