A few weeks ago I bought the Arlo Pro system with 4 camera’s to be used in Europe from BestBuy NY.
I tried to charge the batteries with an adapter for the different plug (US/Europe) but the batteries are not being charged.
Can you let me know how to overcome this problem?
PS
It's using quick charge tech...adapter is 5v usb and 9v to charge. ( pack charges to 8.4v when full )
Hi,
Have you tried using a quick charge 3.0 capable usb wall charger? See example one below that is available on amazon.
it may work.
https://www.amazon.com/gp/product/B01BBZJ31Y/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
Hi
I purchased Arlo Pro system from US for use in UK. Purchased cheap US to UK plug adapter (£2.99) from Tescos and charging works no problem using the provided usb plugged into 2 pin plug plugged into UK adapter.
