Charging Port Cover
  • 5 Replies
  • 6349 Views
  • 2 Likes
AndyUK
Has anyone else found that the charging port cover on the camera doesn't stay in?  Several of mine keep popping out.  Support say send them back to Amazon for a replacement but I suspect the new ones might be the same.
AndyUK
It kind of resolved itself.  I cleaned the ports and covers thoroughly to remove any manufacturing deposits and after a few re-insertions of the covers they stayed put. I haven't had any problems since even though all the cameras have been charged a couple of times.
Hope this helps.
5 REPLIES 5
For starters, be gentle.  🙂
I've had one pop out on me so I used a small jeweler's screwdriver to gently work the tabs back into place. No problems since. Make sure the little tabs are actually in place.
AndyUK
Thanks for that - are you talking about if the cover comes off the body completely?
My problem is that the cover won't stay pushed in (in other words covering the port). I can't see which tabs you are referring to.
Yeah, mine came completely off. I have had problems getting the cover back in on occasion but with some wiggling and "coaxing" I triumphed.
Tribal2204
I'm having the same issue, did you ever figure it out? I'm concerned about the waterproofing of them if that cover doesn't stay seated.
AndyUK
Hope this helps.
