- 2
My batteries on 2 of my Arlo cameras were getting low and I decided to bring them in and charge them up. Up to this point they have been working great. However, when I plug the camera in to begin charging a message on my mobile app shows up and states the following: "A charging fault has been detected. Unplug and reconnect the charger from the camera side of the plug. If this error message persists, see KB article for Charing Faults" I have reviewed quite a few troubleshooting chats and nothing seems to work and the message persists. Also, I can not find the "KB Article". Can anyone help me out as the cameras are only 1 year old. Thank you for your time!
@rrarlo2019 wrote:
Has your problem been rectified? I have the same issue. Same error message, using original charging cable only and the battery charge status is stuck at 7%.
The camera lens and LED lights appear to be working, as I get notifications when the cable is in, but I have no idea whether the battery is in fact charging or not.
Do you have more than one camera?
Arlo sent me a new camera so yes my problem has been fixed.
Same exact issue. Arlo has the customers on a goose chase with no reliable solution. My solar panel quit after 30 days. Poor design and poorer service.
Did you ever get yours to charge?
Same problem here, message there is a charging fault.... We have been on the TALL ladder three times this month to plug and unplug...It seems to work perfectly , but I see the back up battery is draining not charging. Then we start getting the messages again. I have changed cameras in that area (one was stolen) it is hard for me to keep track of which one is new. I never dreamed I these would be so much trouble and I would have to keep a record of their serial numbers. Nothing in the instructions about that.
Are you using a third-party charger?
Also, have you tried swapping batteries with a different camera?
- 2
