Charge fault on Arlo Pro 2 plugged into power
I have an Arlo Pro 2 camera without a battery plugged into wall power. I keep getting a charge fault message on my app which suggests to me to unplug power and plug it back in. Unplugging power and then restoring power does not seem to make a difference. The message keeps cropping up. The camera is working fine however.
IOS or android
Android
Verify that you're using the Arlo charger and that your firmware is up to date. If all is good, try removing the camera from Settings, My Devices and resync.
