Cant Start My Arlo Pro VMC4030
  • 1 Reply
  • 727 Views
sidgala
I bought an Arlo Pro 4 camera setup last year and started using it few days ago. I am unable to start 1 of the cameras after charging them the first time. I tried pressing the "sync" button on the camera but there is no response. I also tried charging it multiple times and I only get a blue blink light for the initial few seconds. I am unable to figure how to fix the problem. Please help.
Streak2
Master Master
Assuming you have managed to sync the other 3 cameras.
Remove and refit the battery in the 4th one.
Then try and sync (short press of the sync button on the base station and a 2 second press of the sync button on the camera).
If that still does not work then plug the power supply into that camera and try and sync again.
Let us know how you go.
