Hi
I just want the inside Arlo pro camera to trigger the siren, but not the outdoor cameras...is this possible?
Thanks!
Thanks!
The answer I saw does not seem to work for me. when I use the mode change, it changes all the cameras, not just the one's I want to adjust. How can I just turn off motion on specific cameras but leave the others on? Is there a possibility that upon setup, it was done incorrectly? When I go into the Mode tab, it shows a picture of just the main base under My Devices. It does not show each one of the cameras individually. At this point I only have 4 options.
Armed
Disaarmed
Schedule
Should it be different than this? If so, what do I need to do to change it? I currently have 5 cameras and may add more in the future.
Jeff
jeff_abramson,
Armed and Disarmed are default modes that contain rules for all cameras synced to your base station.
To Arm some cameras and disarm others within the same mode, a custom mode must be created.
Take a look here for more information: How do I create a mode for my Arlo Pro Wire-Free camera?
