Can you set certain cameras to trigger siren and others not?
  • 4 Replies
  • 4649 Views
mrshanno
Hi
I just want the inside Arlo pro camera to trigger the siren, but not the outdoor cameras...is this possible?
Thanks!
Yes. All settings are in your modes and rules in the Mode tab.
mrshanno
Thanks!
jeff_abramson
The answer I saw does not seem to work for me. when I use the mode change, it changes all the cameras, not just the one's I want to adjust. How can I just turn off motion on specific cameras but leave the others on? Is there a possibility that upon setup, it was done incorrectly? When I go into the Mode tab, it shows a picture of just the main base under My Devices. It does not show each one of the cameras individually. At this point I only have 4 options.
Armed
Disaarmed
Schedule
Should it be different than this? If so, what do I need to do to change it? I currently have 5 cameras and may add more in the future.
Jeff
jeff_abramson,
Armed and Disarmed are default modes that contain rules for all cameras synced to your base station.
To Arm some cameras and disarm others within the same mode, a custom mode must be created.
Take a look here for more information: How do I create a mode for my Arlo Pro Wire-Free camera?
