Can the new Arlo pro cameras be plugged into an electrci outlet where they are mounted????
I will be gone for 5-6 months and do not want the bar=tteries to go dead inside and outside makeing the cameras useless.
Yes, but...
The use of the charger and cable eliminates the watertightness. You'd be on your own to seal the camera up and protect the charger. Netgear specifically disavows this sort of thing so it's up yo you to figure it out and handle any potential warranty issues.
Yes, but...
