  • 28123 Views
Stevenross
 At the moment my connection is wired and I'm curious if it's possible to connect wirelessly? Thank you very much for everybody's feedback
Streak2
Master Master
The base needs to be connected by Ethernet cable to the router. No wireless option.
Streak2
Master Master
You can use a WiFi extender with an Ethernet port.
Stevenross
Thank you. I'm going to try the wifi extender and plug it into it.
